Results 1 to 10 of 10
Thread: Virginize bsi
    Junior Member MJeppesen24's Avatar
    Jan 2018
    Denmark
    Default Virginize bsi
    Hello DK
    I wanted to hear what equipment you use to read and write PSA bsi?
    I am new to this industry.
    Help = Thanks + Reputation Button
    Equipment I use
    DIAGBOX 7.83 ( soon 8.55 )
    TDB007
    KESS V2 - clone Still learning
    KTAG - clone Still learning
    rafal's Avatar
    UK - PL
    e.g. xprog or upa
    need help
    now my goal is to buy xp-005
    who will help?
  3. The Following User Says Thank You to rafal For This Useful Post:
    MJeppesen24 (18th February, 2018)
    Jan 2018
    Denmark
    I would like to take a closer look at them
    thank you.
    What about I/O Terminal?
    Equipment I use
    TDB007
    Oct 2017
    TL866 programmer works great. And also you can do it with terminal.
    Jun 2013
    PANDO, URUGUAY!!!
    HI , any bsi you can virginize whit all dump in FF but in other specific you need a specific dump or the bsi it will not work . And any bsi as the jhonson controls brand you can see the data directly in the asc2 code whit any programer and others as siemens and valeo the data is encrypted in this case you can use the function of the inmokiller program in citroen brand have for encript/de encript citroen-peugeot bsi dump, you open the dump and de encrypt and after you can see the real data in the asc2, have pin code chasis and if write FF in this data and after encrypt again whit inmokiller (you have to write this new dump ) .The bsi are virgen of pin code and vin, and can program in other car
  7. The Following User Says Thank You to electronicscars For This Useful Post:
    martinracing (12th March, 2018)
  8. #6
    Jan 2018
    Denmark
    I have read a little about the different possibilities there are. I / O Terminal and Smoke, appear to be some really good prog's.
    But what software options are there for making a virgin file of PSA BSI
    with best regards
    Equipment I use
    TDB007
  9. #7
    rob h's Avatar
    May 2011
    You can download the software and run it without interface.
    You will get a glimps of what it can do!
    Quote Originally Posted by MJeppesen24 View Post
    with best regards
  10. The Following User Says Thank You to rob h For This Useful Post:
    MJeppesen24 (4th March, 2018)
  11. #8
    Jan 2018
    Denmark
    Quote Originally Posted by rob h View Post
    thanks ..
    I will try that
    Equipment I use
    TDB007
  12. #9
    Mar 2016
    South Africa
    HI guys could anybody help me with a virgin dump for a w203 eiz
    vin WDC2030452R037306
    thx guys
  13. #10
    Member mandriao's Avatar
    Oct 2016
    Brasil
    Hello DK
    Hi man. You can use by OBDii whit PSA-Tool
