Genuine tools including Abritus, Autotuner Master, Bosch Ford vcm2, smok UCDS FULL JTAG FULL pcm flash, IO terminal, UPA, Autel maxicom pro, MTX dpf, dtc, immo edc17 UCDS, and a little well maintained hairy box from china I play inside!
4.94 x100 fgtech kess ktm ktag mpps skp. And still collecting
Ok that's good news. When I get home I will get you my origoanl files and you can try them. Does ktag ask you if you want to do the chks?
@Makri: You need disable restore and flash mpc and eeprom weird in K-TAG
Sedat Garip
Chiptuning Remapping, file service, stage 1 & 2 dyno tested.
Diesel + petrol All cars
Manual Adblue dpf egr Opf tested working solutions
Belgium
With Kind Regards,
Don't forget hit thank button if i helped.
norman1967 (20th February, 2018)
I have kess read 2177kb from cpu i bought for learning If need write pm i'll send it to U.
HW:
SW: 1037529583
VIN nr.:
SW ver.:
Spare:
Engine:
HW Ver.:
SW upg.: P564_OB8
Installation: P153 - Bosch EDC17C19 Opel
Yes I did, it must be a problem with my Ktag. I have solved the issue now
Thanks a lot. I flashed the 160hp ori with ktag, it also got corrupted like my ori file but not that much. This file already have data in that corrupted area and it looks like it helped.
The car started with the flash and also Kess IDed the ECU.
I then flashed my tune file using Kess tricore and it wrote it with no issues, then read it again and its a 100% match so no problems with Kess tricore on this ECU using 2.23sw and 5.017FW
So looks like the problem is with my Ktag or 7.020 ktag in general for this ECU.
Thanks mate appreciate it, but I just solved my problem
