[QUOTE=makri;3220652]Yes I did, it must be a problem with my Ktag. I have solved the issue now
Great and well done for posting back your findings this will help others in the future
Genuine tools including Abritus, Autotuner Master, Bosch Ford vcm2, smok UCDS FULL JTAG FULL pcm flash, IO terminal, UPA, Autel maxicom pro, MTX dpf, dtc, immo edc17 UCDS, and a little well maintained hairy box from china I play inside!
4.94 x100 fgtech kess ktm ktag mpps skp. And still collecting
Check PCB.. most probably damage during opening...
Try to put ignition on without ECU you will got LOW FUEL. Try with ECU will get the same LOW FUEL.... Need replacement unit, EEPROM shift and IMMO off.
Didnt you say, that yo using KTAG. Why your stock is partial read???? Looks like overwritten via OBD.
Find full stock and write with another KTAG, KESS tricore, Galletto or MPPS v18.
I have a scalpel, I want to become a surgeon, what else do I need?
jimmy060 (11th April, 2023)
