Results 1 to 5 of 5
    peko's Avatar
    Default 307 BSI HS912DG128 => Swap ?
    Hi friends.
    I need swap BSI from old 307 with HC912DG128 inside.
    I already made this job but this car no way.
    I read Motorola eeprom and write it in BSI second hand, but when i want Telecode keys, PP2000 say me code PIN incorrect.
    If i use same PIN Code in original BSI, PP2000 accept this code.
    So where is problem?
    File eeprom from original BSI with PIN Code: ASB9
    In this case You must to program the second hand bsi with a virgin dump (pp2000-> replacements parts-bsi replacement...)
    Jun 2013
    PANDO, URUGUAY!!!
    THIS IS THE FAMOUS VIRGIN DUMP, THE DUMP IS IN INMOKILLER PROGRAM
    Jun 2013
    PANDO, URUGUAY!!!
    AFTER YOU WRITE THIS DUMP, HAVE TO PROGRAM WHIT PP200, pp2000-> replacements parts-bsi replacement.
    Feb 2012
    France Paris
    you can't use eeprom clone if the software is not the same
