    Feb 2018
    Default Peugeot 206 cc automatic
    I have had to get a donor Bsi/ecu as old one died. Donor had no code but do have vin number. How do I get code to reprogramme in digibox and how do I do it.
    Donor vin is Vin number is
    Vf32dnfur42170179. Thank you.
    WinWoj's Avatar
    Jan 2012
    ECU City
    ecu without pin may be a problem... then could be an immo off making.
  3. The Following User Says Thank You to WinWoj For This Useful Post:
    xOxOx (22nd February, 2018)
    Nov 2017
    Would you use kess v2, mops or galletto for 206?
    On bench or obd?
    Nov 2016
    read 29F400 and eeprom then immo off
  6. The Following User Says Thank You to Shakeelbhugeloo For This Useful Post:
    Feb 2018
    cheers for the replies, however I am not sure of any of this apart from using diagnosis on obd,
    Immo immobiliser!
    kess v2, mops or galletto?
    read 29F400 and eeprom then immo off...... More info I don't understand., sorry.
  8. #6
    Nov 2017
    Digibox needs code card from dealer with v5 and driving license, to get past the immobilize. ECU needs to be put in boot mode to read the chips that hold the data. You could them read with a remapping tool like Kess, mpps galletto on the bench.
    But be warned, taking any chip off the circuit bored is very hard, soldered smd, and glued on. Heat needed.
    Don't know what ECU is in your car, but the edc15 need a chip (95p08) taking off to get in boot mode.
