Results 1 to 8 of 8
    Default 2013 Honda CR-V 77960-T0A-X911-M1 please clear
    Please clear 2013 Honda CR-V 77960-T0A-X911-M1 95640 eeprom, thanks in advance
    Jul 2016
    USA
    here is cleared file. pass in pm.
    please give thanks an rep
  3. The Following User Says Thank You to borshch For This Useful Post:
    daremen (22nd February, 2018)
    dragon100's Avatar
    Jan 2012
    From land of milk and honey
    Try and report.
    Best regards.
    Dragon
  5. The Following User Says Thank You to dragon100 For This Useful Post:
  6. #4
    magnacin's Avatar
    Quote Originally Posted by daremen View Post
    Just 00 from 240h thru 7AFh
    "I find your lack of faith disturbing"
    If you found my post useful, please use the "Thanks" and "Rep" buttons.
  7. The Following User Says Thank You to magnacin For This Useful Post:
  8. #5
    it worked fine!!
  9. #6
    Quote Originally Posted by dragon100 View Post
    Try and report.
    with this file appear code DTC 81-64 (FCU serial number ID code inconsistent) (internal failure of the front passenger's seat weight sensor unit)
    maybe the data for the calibration of the passenger weight sensor is deleted
  10. #7
    dragon100's Avatar
    Jan 2012
    only need calibration seat weight ...
    Best regards.
    Dragon
  11. #8
    Apr 2017
    México
    pass please
