here you go
bugarcek (22nd February, 2018), lapinoumalin (12th March, 2021), rajivc666 (2nd May, 2019)
Here your file, try it and post result after few weeks
Press thanks + rep. PW in PN
bugarcek (22nd February, 2018), lapinoumalin (12th March, 2021), Pacsat (13th March, 2019)
With old software number yes but with new regeneration makes problem if u want u can send me your pass. Than i can check your Solution
Tuning Cars and Trucks, Immo off , DTC delete, DPF off
Made 03L906018PR_9980 and 03L906018BR_9977 oth after NOx update
Today I get car back... Customer very angry because again dpf light, until now it was used Johak solution... When I loaded map I also changed diff pressure sensor and we also make regeneration.
Here are uploaded 2 variants of egr off and my original file...
Can someone take good look at files... I do not know what to do now... A lot of people say that when egr off is made that dpf not work anymore... But I know that it work at some cars, because I done alot of 1.6tdi and 2.0tdi and dpf was not problem after egr off.
Try my solution, for me it works, maybe you must also delete some errors. I try also Johak solution, but for me never works.
If you need error deleted let me know.
When i tried same solution as Johak it don`t work the service regeneration. Try this with Johak files and then try it with mine. Service regeneration should work and then works also normal regeneration. That`s my expirence.
Maybe you can send me a solution for 1.6TDI, made last few weeks two one and at the moment with my solution regeneration works.
But when i log postinjektion 1, i see injektortime 0,19-0,26 microsec. Until now i have no original 1.6TDI for check if original soft do the same.
bugarcek (20th March, 2018)
Thanks for answer. But service regenration works with johak file aswell... It looks like that normal regeneration does not work.
I have no working solution my friend but it do it on same way as your and this not work also egr off yes But Dpf regeneration not . And I test the same sw version
