Page 2 of 2 FirstFirst 12
Results 16 to 22 of 22
  1. #16
    Jun 2009
    My girl friend drives over 3 years with EGR off file and regeneration works fine, but it is a EDC17CP14
  2. #17
    Nov 2011
    EU
    Default Audi a3 2.0 tdi edc17c46 egr off
    Today I made egr off on audi a6 2.0 tdi 2012...
    Howeever same ecu edc17c46 and same engine...
    When i made it i checked readiness in vcds an look at photo... Before I made egr off there was egr failed status but now it writes >Not installed<
    There must be something wrong with egr off on some sws because on audi a3 there was still written egr failed...
    It is not only about this car but also on some other 1.6 tdi and 2.0 tdi...
    There are few % of total egr of made that make problems
  3. #18
    sdtsedat's Avatar
    Jan 2015
    Belgium
    You can see your egr valve in % look at measure blocks.
    Gr.
    Verstuurd vanaf mijn SM-G955F met Tapatalk
    Sedat Garip
    Chiptuning Remapping, file service, stage 1 & 2 dyno tested.
    Diesel + petrol All cars
    Manual Adblue dpf egr Opf tested working solutions
    Belgium
    With Kind Regards,
    Don't forget hit thank button if i helped.
  4. #19
    Fec001's Avatar
    Default EGR off
    Can someone pls make complete EGR off? i have DTC P0403.
    I know regeneration will not work anymore but its not problem.
  5. #20
    Jun 2012
    Do you have news for EDC17C46 egr off without dpf removal? Is it only possible with pre-dieselgate sw? Or it doesn't matter if we touch normal mode hysteresis only?
  6. #21
    jurebv's Avatar
    Dec 2017
    Croatia
    Just touch normal operation hysteresis , dpf works fine
    2WD Dyno , Magpro2 X17, FLEX Master , KESS Master , AUTOTUNER Master, Byteshooter Master, EVC Winols Reseller
    FILESERVICE: Tuning / DPF / EGR / Adblue / DTC / Immo
    Official Magicmotorsport Distributor
    Official Autotuner Distributor
    Official Alientech Distributor
  7. The Following User Says Thank You to jurebv For This Useful Post:
    cawadany (20th January, 2020)
  8. #22
    Jan 2017
    Hello, is there a solution found?
    I have exactly the same hw/sw as the first version, and I guess I'll have the dpf problem. From now I switched hysteresis maps 1 2 4 5 to 0 and P0403 off but I still have limp home mode when oil temparure > 70°C, I guess "normal maps" are 3 and 6... but it looks like Johak's map, that seem to cause dpf off also.
    If I unplug the connector and make a dtc off of the error that will occur, can it be a solution?
