Results 1 to 3 of 3
    Feb 2018
    POLAND
    Default RENAULT MEGAN PIN KEY PROGRAMING
    Hello !
    I have a problem with renault megan 1. Diode immo does not flash, in immo parameters there are no programmed keys. This is the result of firing another car on the cables, and after extinguishing the car is no longer wound. I read hc05b32 UCH 8200029340B I calculated the pin code. (please check if it is correct) I start the renault clip and try to program the keys but after entering the code and trying to finish the key learning is still not possible. Does anyone have a step-by-step procedure for coding the key with a clip renault megan.
    Can old transponders be used for repetition?
    leonek4 :spokojna:
    Oct 2013
    Serbia,Mladenovac
    PIN is 13 68 55 37
    Feb 2018
    POLAND
    Thanks, I use a good pin.
    How to programing key?
    Use the new ID60 transponder ???
    leonek4 :spokojna:
