I got kit like this and it''s quite good (also a's token saver ). If you got big balls also think about fvdi 2014 - but in this case you have to be carefully
Good morning to everyone.
I'm a locksmith in Greece, i already own a zedfull, but i'm intersted in buying an obd key programmer as a coverage for zedfull, specially for older and japanese cars.
Does the ck100 with obdstar x100 plus, make a good combination for the above purpose in europe?
Any other suggestions?
Thanks in advance...
kostat (22nd February, 2018)
Thanks for the reply brother.
Why do i have to be carefull if i want to buy fvdi? is it because there are many versions of it?
Ck200 is much better than ck100
In what ways is ck200 better? Other functions?
kostat (29th March, 2018)
Most cars listed, but even has more in the menu that are not listed in PDF.
kostat (23rd February, 2018)
and even more in the extended menu for the add on box
I m prefer Obdstar, I own Xtool x100pro, this tool same as Obdstar x100 pro and not much different. It support most Japanese car region and International model. At what i have been told by old friends (ImmoGurus) not all key programming tools can do all in one. You must have a good combination key programmer. As mine I using OBDSTAR J-C for immo code calculator, is not too expensive, at least it works for the job to get PIN CODE successufully and do Key Programming with X100. My next coming tool is OBDSTAR X300 Pro3, the manufacture claim that it can get BSI Pin Code for Peugeot mean I don't need anymore X programmer, just using OBD2 socket. Anyway good luck. Regards
kostat (26th March, 2018)
Thaks a lot...I'm in europe, is x-100pro by obdstar a good choice for cars (japanese,european) in europe?
Yes..you can ask the person at OBDSTAR website and get of Car support list. There is a Car Region you can choose it. Most of the scanner/ key programming Made in China should support worldwide brand and Region but not all model. If you wanted to do more job, better invest it on OBDSTAR X300Pro, if you have more budget go for OBDSTAR X300DP with better interface and android application. For myself , started learning with Xtool X100pro and Zedbull clone. But learning key programming and troubleshooting, that is no ending. The more you used it, much experience you will get it, keep trying and get more experience ..I m also keep learning everyday.... Regards
kostat (28th March, 2018)
