Results 1 to 15 of 30
Thread: MB EIS w203
    Jul 2016
    Default MB EIS w203
    Hi Dear all
    I have Mercedes c200 with eis w203 the car is working, but the problem is with eis doesn't start the car when I am try to turn the mb key to start the car nothing is happen the key is working fine I test it with vvdi mb and it turns the first acc and on position but when I turn to start position to start the car nothing is happen.
    could you please tell me how can fix this kind of problem
    bladymir's Avatar
    Dec 2016
    Spain.Malaga
    Hello mate.
    If the key turns but the car does not start-EZS with Key + ESL works fine.
    What error codes does the diagnosis machine give you?
    It can be a thousand reasons not to start.
    In the front SAM there are three fuses that power MOTOR ECU and ABS.
    It is very important that you do a global check of all systems.
    Remote control works?
    workshop
    first check fuse for start relay sam front
    Jul 2016
    Yes the steering lock is working and the dash lights is on only the remote doesn't work because of the key is old one and the starter is working when i am trying from engine side with the starter the car is startup.
    bladymir's Avatar
    Dec 2016
    Spain.Malaga
    Fault codes???????
    pepi's Avatar
    With MB Star go to the CDI and actual values , check drive authorization .
    Nov 2016
    I have same problem with mercedes S320 but sometimes its good and somtimes wont start
    bladymir's Avatar
    Dec 2016
    Spain.Malaga
    Guys, I think that without Star Diagnosis it is very complicated to know why the Mercedes does not start.
    As Pepi says, first you have to look at authorization-EZS-ESL-CDI.
    W220-EZS, CDI, selector lever.
    If there is permission to start all modules-you have to look at injectors, sensors, etc ........
    If there is no authorization then there are problems.
    Mar 2013
    Europe
    We can only Help when you post Screens in ENGLISH!!!
    Sorry, cant help!
    Feb 2011
    I had the same problem. W203 das3 key faulty...learn a new key and the thing will work��
    Jul 2016
    I have read the eis and make new key but the car not start as before so the problem not the key
    pepi's Avatar
    Check ECU.
  13. #13
    Jan 2018
    replace the key. 90% of the time is a bad key
  14. #14
    Jul 2016
    I did but no solve
    Quote Originally Posted by gkinz View Post
  15. #15
    Nov 2016
    DO you need to replace Or reprogram the Key ?
