    Jan 2012
    Default EDC16U34 MAF MAPS ADDRESS HELP
    Need help for MAF IQ limitations addresses !!!
    johak's Avatar
    1D6210, but here smoke limiter is by MAP
    Top Poster mack0r's Avatar
    Mar 2017
    it seems to me that in edc16u34 you will find IQ by MAP And lambda maps. This car should be limited by these maps. I did not check your file. I write from my experience. I do not have access to the computer now to check your file.
    Jan 2012
    Can you please check and confirm this will help a lot !!
    Mar 2017
    if you are not in a hurry this evening I will make you a map pack for this ecu. I'll be at home only in the evening.
    Jan 2012
    Many thanks for your help , I have already a mappack but I try to understand how is selected maf and map , to help me to understand , I'm also looking for some switches :
    1. Smoke limiter via lambda / IQ
    2. Lambda full load regulation
    3. MAF/MAP smoke limiter
    4. Calculation based on MAF/MAP
  7. The Following User Says Thank You to vwstuff For This Useful Post:
    sep382 (19th July, 2018)
