K-tag do by J-tag, you must open ecu. Eprom I read Uhds by obd
FILE SERVICE
oliva (23rd February, 2018)
Hi friend
I/O Terminal no open ecu
Ecu powered, Dtc, Egr, Dpf, Throttle, Flaps, Lambda, Hotstart, AdBlue, Evap, Nox, Speed limiter, Dynotest development.
Piasini, Fgtech no open ecu ?
pcm flasher , alex flasher
REMOVE ALL DTC-EGR-DPF-FAP-FLAPS-CHIPTUNING-IMMO-CRASH
CLONE ALL VAG ECU !!! REPAIR DUMP ELV,EZS COMFORT AND ECT..
REPAIR DUMP STEERING ANGLE SENSOR !!! REPAIR DUMP BCM2 !!! KEY PROGRAMMING !!!
