Hi friends, in this Vw Up Tsi 1.0 revlimiter when the car is disengaged, is
4000RPM, I want to find where is this limiter and change to 5000RPM,
someone can help me?
and if possible discovery what is these maps 26D4DE, 26D5AC?
Thanks in advance
Thanks in advance
anyone have any idea?
You found?
No, i dont find yetl
do you have some idea?
vinsk8 (25th February, 2018)
Hi there,
Sorry to disappoint You but it is a very very bad idea to rise this NoLoad limiter to these engines. They are very sensitive... and this is the reason there is a NoLoad limiter factory installed. Trouble is an easy thing here specially if You try to make a launch control... as i suspect
Do not forget that these type of four wheel boxes are made to take You from point A to point B like the home to Supermarket... and are NO base for performance tricks... Ask a VW dealer and You will understand what i mean.
Good luck!
Knowledge is to share... so if I have helped just press [Thank You + Rep.]...
speedy100 (26th February, 2018)
