anyone have any idea?
You found?
No, i dont find yetl
do you have some idea?
vinsk8 (25th February, 2018)
Hi there,
Sorry to disappoint You but it is a very very bad idea to rise this NoLoad limiter to these engines. They are very sensitive... and this is the reason there is a NoLoad limiter factory installed. Trouble is an easy thing here specially if You try to make a launch control... as i suspect
Do not forget that these type of four wheel boxes are made to take You from point A to point B like the home to Supermarket... and are NO base for performance tricks... Ask a VW dealer and You will understand what i mean.
Good luck!
Knowledge is to share... so if I have helped just press [Thank You + Rep.]...
speedy100 (26th February, 2018)
