Results 1 to 13 of 13
    dd1's Avatar
    Aug 2014
    Default MBZ CL500, W215, EIS SWAP WITH KEY
    Hi everyone. I have a mbz cl500 that has an eis problem. it work when i heat it up with a heater gun and later on stop when its cold. i have kind of played with the mcu so i assume that i messed up the mcu. i have purchased another eis with a key from a scrap yard. how can i get this key working on this car. its a 2003 CL500. Thnx in advance
    brend's Avatar
    Oct 2015
    Same where
    Press thanks+rep.
    Write original eep..
    workshop
    clone old eis,if you chip hot make,you can read
  4. The Following User Says Thank You to mercis For This Useful Post:
    dd1 (24th February, 2018)
    dd1's Avatar
    Aug 2014
    The problem is that I suspect I might have messed up the data......that's the problem
    Apr 2016
    holland
    it is easy job if you have right tools make ezsa virgin with abrites and order grey key by dealer
    dd1's Avatar
    Aug 2014
    I can't order anything from the dealer, they won't sell.
    Mar 2013
    Europe
    How is the Problem ?
    Read eeprom from Original EZS and write to Donor EZS ;-)
  9. The Following User Says Thank You to bersch8688 For This Useful Post:
  10. #8
    dd1's Avatar
    Aug 2014
    Thnx but this Eis has 2 mcu. Which one should I work on? I think I have worked on R2....should I work with that mcu eep? Thnx
  11. #9
    magneto21's Avatar
    Jul 2016
    if u have the used ezs with working key-what I think you have
    there is one way to do it ,
    virginize the ESM,ECU.IKE and programmed with MB star diagnostic scanner
  12. #10
    dd1's Avatar
    Aug 2014
    Ok Ecu I can, esm I need help what's the IKEA?
  13. #11
    magneto21's Avatar
    Jul 2016
    dashboard instrument cluster
  14. #12
    dd1's Avatar
    Aug 2014
    That's a lot of work. To read eep and use the original eep is the easiest. So, should I use the R1or R2 mcu data?
  15. #13
    dd1's Avatar
    Aug 2014
    Anyone?????????
