Results 1 to 12 of 12
    Nov 2016
    Default MERCEDES EIS MCU
    Hello i have an Eis module with one damaged MCU .
    I cant read data on it also.
    If i buy another MCU same number where do i find data to put in the MCU ?
    are both MCU content the same ? same Data ?
    Or should i change the EIs unit and match key ?
    pepi's Avatar
    What is the model of car and number of EIS.
    Mar 2011
    Vilnius,Lithuania
    Quote Originally Posted by Shakeelbhugeloo View Post
    if all eis have same data then all mercedes will start with same key
  4. The Following User Says Thank You to xyznia For This Useful Post:
    bersch8688 (24th February, 2018)
    Nov 2016
    Mercedes C180 Eis 210 545 0308
    i have one damaged mCU
    my question is if i manage to get a MCU and dumps for the 2 MCU from another car and put in my new ones and then re program keys will it works ?
    Mar 2013
    Europe
    Think/Say NO!
    You can buy New MCU but write DATA from other Car ---> thats not work!
  7. The Following User Says Thank You to bersch8688 For This Useful Post:
    Shakeelbhugeloo (26th February, 2018)
  8. #6
    Nov 2016
    but is there virginise dump for these mcus ?
  9. #7
    Jan 2018
    one MCU has key data. and other has vin and miles. so what chip is bad?
  10. #8
    Nov 2016
    Key data chip
    where do i find dumps for these ?
  11. #9
    Dec 2017
    You can buy Eis 210 545 0308 (second-hand) then write DATA from MCU2 EIS thats not work!
  12. The Following User Says Thank You to canbus7 For This Useful Post:
  13. #10
    Nov 2016
    Okay thanks
  14. #11
    pepi's Avatar
    W202 with EZS who have inside two motorola HC05.
    Simply ,find one used EZS and USE motorola HC05 with YOUR data from another HC05 that is working one.
    This model DOES NOT HAVE VIN inside data.
  15. The Following User Says Thank You to pepi For This Useful Post:
    Shakeelbhugeloo (28th February, 2018)
  16. #12
    Nov 2016
    Thanks Man goodinfo
