Thread: GM 13580198 BCM
    Jan 2014
    Default GM 13580198 BCM
    hello friends
    please my BCM have broken eprom 24C16 so I replace it with new ic
    so please I need dump file for this BCM
    thanks in advanced
    clusters's Avatar
    Mar 2015
    Canada
    I doubt a dump from another BCM will help you, that is from a Global A system and will require a new module from GM and then be programmed.
    Besides, the dump would depend on year make and model, not part number.
    FYI: https://www.youtube.com/watch?v=IeB3T-UEJeE
    Jan 2014
    I have Chevrolet Camaro 2011
    I make immo off for ecu
    I buy new Bcm for car but when connect it not work only I can run car
    so I need fie to make bcm work on car
    I have original new bcm file can you edit file to make work
    Jan 2014
    any help please
    hexguru's Avatar
    Nov 2016
    You need sps programming online! It is not difficult you for this needed gm mdi or passthru supporting GM Lan (open port, avdi and so on) and someone who have
    extended GM account and via TeamViewer you can do this
  6. The Following User Says Thank You to hexguru For This Useful Post:
    a1m1m1a1r1 (27th February, 2018)
    Jul 2015
    If you have a GM account i can connect you via teamviewer and program it for you. very simple as ABC have done many of this car online via sps online GM account.
    Always show appreciation to ur helper NO + THANKS = NO HELP
