Page 1 of 3 123 LastLast
Results 1 to 15 of 40
    Default 2018 Toyota Camry 93C66 13372 km need 5000km
    camry 2018 13372km 93c66.rar please calculate to 5000km thanks in advance
    Dr. Zoidberg's Avatar
    Oct 2015
    Talca-Chile.
    Quote Originally Posted by daremen View Post
    that does not look good, read back, and remember 16 bit.
  3. The Following 2 Users Say Thank You to Dr. Zoidberg For This Useful Post:
    DashProg (23rd February, 2018), sagie1zn (23rd February, 2018)
    I´ve read it back and I have the same result
    Landetos's Avatar
    Mar 2013
    Inside EnigmaTool
    Quote Originally Posted by Dr. Zoidberg View Post
    Reading is correct.
    Thing is its new SW.
    Not a 93C66 marked eeprom.
    Eeprom is marked as RH66...
    New algo...
    Live by the rules and die by the rules...
    Thank before you die...
  6. The Following 3 Users Say Thank You to Landetos For This Useful Post:
    DashProg (24th February, 2018), Dr. Zoidberg (23rd February, 2018), sagie1zn (23rd February, 2018)
    You are right, EEPROM marked as RH66
  8. The Following User Says Thank You to daremen For This Useful Post:
    Landetos (23rd February, 2018)
  9. #6
    Oct 2015
    Talca-Chile.
    Quote Originally Posted by Landetos View Post
    Reading is correct.
    New algo...
    Thanks, for the info Landetos, I have an idea, but to confirm, i need other dump.
  10. The Following User Says Thank You to Dr. Zoidberg For This Useful Post:
    Landetos (26th February, 2018)
  11. #7
    Take the eeprom off the board, then power up the cluster again and the original mileage will still be displayed (in KM this time if your cluster is in miles). So either there is other memories on the board or the absence of the eeprom makes the spansion cpu display the last image of the mileage. Anyways here's a file for you. Load this dump file as is and see what happens or if you find something let us know.
    Thank you.
  12. The Following User Says Thank You to Speedosoft For This Useful Post:
  13. #8
    Here is another dump with 26929 miles. I changed line 50 miles doesn't change. Any ideas ?? Chip says RH66 reads fine as 93c66.
    I need 5500 miles. If anyone has power up let me know cause I have cluster coming back and we can play to figure this out.
  14. #9
    clusters's Avatar
    Mar 2015
    Canada
    Line 50 calculates to 25881 if you use the Denso algorithm, it may be the trip odometer.
    Need to put a few Km on it and read again so we have a good comparison.
  15. The Following User Says Thank You to clusters For This Useful Post:
    jomberykaso (27th April, 2018)
  16. #10
    May 2011
    hi
    eeprom is msop....???
    post picture
  17. #11
    Chip is Tssop 93c66 labeled RH66. MCU is an ARM. Dump is already posted
  18. #12
    ascrap2003's Avatar
    Sep 2016
    Texas
    Is new corolla like this too? 2017 US model Just did one denso, removed eeprom wrote manually and soldered back and bam cluster dead no display, no nothing! Have another on order from LKQ but I was thinking micro smd cap next to eeprom!
    Had a issue Had a issue with my uploads so if you see one of my posts and need that dump let me know and I'll post it!
  19. #13
    afitijuana's Avatar
    do you solve this one ?
    I have the same trouble
  20. #14
    May 2011
    hi
    my tool read perfect but wont write...it says write area protected wont write...no change nothing...same in corolla and camry v55....power up good read perfect but wont write try on 4 different cars wont work...
    if any one has solution post here..
  21. #15
    mecjp's Avatar
    Oct 2013
    other world
    Quote Originally Posted by digimile View Post
    hi
    did you have read incircuit? or desolder?
    sharing is the key of success
