Results 1 to 5 of 5
    Feb 2017
    Baltic
    Default AUDI Chorus car radio pin
    014AUZ1Z2Y6972452
    7 648 245 380 ;
    Serial number: AUZ1Z2Y6972452
    Is it possible to get the pin fron sn or I need to take the radio apart?
    lucic66's Avatar
    Aug 2015
    Quote Originally Posted by mikkhh View Post
    014AUZ1Z2Y6972452
    7 648 245 380 ;
  3. The Following 4 Users Say Thank You to lucic66 For This Useful Post:
    audiopoint (24th February, 2018), Decode Ghost (24th February, 2018), irfa (24th February, 2018), rafal (24th February, 2018)
    Feb 2017
    Baltic
    Don't have carprog, will try to read the dump using UPA USB v1.3.
    EDIT:
    I read using UPA usb and cartool showed the radio pin 11 17 ; I can try the pin tomorrow, I have attached dump if anybody wants to verify that the pin proposed by cartool is correct.
    Last edited by mikkhh; 24th February, 2018 at 08:05 PM. Reason: added extra info and updates
    lucic66's Avatar
    Aug 2015
    Hi,in calculator edit 1117,its corect.
    EDIT:
  6. The Following User Says Thank You to lucic66 For This Useful Post:
    mikkhh (25th February, 2018)
    Sep 2014
    poland suwałki
    hi I have a problem with read in that chorus radia bin from them, when I solder brown wire its not possible read memory,
    where is problem ? in adapter or CP ?
