hello mates i am facing a problem programming key in this rover
first the client ccame with a non remote working key and he had to touch the key with the steering key antena to start the car so he asked to program new key
i usual i use skp900 normally adding keys so i tried to add key when it comes to in 5s click unlick on key it dosent react to key and programming fails so i tried to make all key lost ereased all keys now car is not recovering even same key that had in memory nor other key
i was told that i have to use SDD to run configuration on KVM keyless vehicule module then it will be ok
but in service function there is no such configuration to run
in rfa module there is 1 fault says ... less then 2 keys programmed
in the back of right side of the car the RFA 23.9 module reference is bj32-19h440-ag i am confused what to do i already tried 315 mkz and 434 etc none worked ...the original key worked befor is 434mhz
can i do on bench key or somthing to solve on bensh like new rfa on bensh programming is needed or what
what should i do please any clue help in my hard time thanks
