Results 1 to 14 of 14
    Jun 2011
    Default help to add 4c key data for previa 2000 model
    hello friends
    pls i need help to add a 4c key for Toyota previa 2000 model
    attached the eprom file from the ecu ic900
    thanks in advance
    siyadk's Avatar
    Dec 2012
    key added
    Hit thanks
  3. The Following User Says Thank You to siyadk For This Useful Post:
    elmaalouf (28th June, 2013)
    Jun 2011
    thanks friend will test and reply
    Jun 2011
    Hello friends
    sorry it didnt work
    any help pls??
  6. #5
    DK Veteran rashid01's Avatar
    Nov 2009
    UAE
    Default prevvvvvvvvvvvvvvvvvvvvvvvv
    ready to start
  7. #6
    Jan 2010
    take a read of what I uploaded a while back may help you
    http://www.digital-kaos.co.uk/forums...on-4c_info.pdf
  8. #7
    Nov 2012
    Data: 7E-B2-FA-32-04-00-00-00-00-95-B1-7E-00-00-
    TYPE: 4C TEXAS.
    Tiris format:
    7E-4D-5F-4C-20-00-00-00-00-A9-8D-7E-00-00
  9. #8
    dijo's Avatar
    Apr 2010
  10. #9
    Jun 2011
    hello friends help pls till now i didnt start my car
    help plsss
  11. #10
    Dec 2009
    Quote Originally Posted by elmaalouf View Post
    hello friends
    thanks in advance
    Hello Mate
    You read the eeprom as 93c56 x 16 bit or as 93c56 x6 bit?
    Best regards
  12. #11
    Dec 2009
    help plsss
    Here you go Mate,
    I have added the 4c tiris data in your first post in two manner depending on which bit mode you have read your eeprom 93c56.
    This said, if you read it in 93c56 x 16 then used the corresponding dump in the attachment to program the eeprom and vice versa if read in 93c56 x 8
    Pass in your PM
    Good luck
  13. #12
    Nov 2009
    Memory device - 24c02/25c020/c040/c080/93c56/c86 - 8 pin SMD.File size - 256/512/1024/2048 bytes
    Used in - Toyota RAV4,Sienna,Corolla,Yaris/Lexus IS200,IS300,GS300
    Transponder to write - JMA TPX1 - Errebi TX1
    Transponder is ready programmed to start the vehicle
    use good tool
  14. #13
    Mar 2017
    Quote Originally Posted by rashid01 View Post
    ready to start
    pleqse pass bro
  15. #14
    Mar 2017
    please bro pass i need it
