X300 Pro3 and DP pad and keymaster DP yes or no fail/success - Page 13
Page 13 of 42 FirstFirst ... 38910111213141516171823 ... LastLast
Results 181 to 195 of 628
  1. #181
    rob h's Avatar
    May 2011
    I tried pulling pin from bcm opel before.
    Mokka 2013 BOSCH 70F3469+24C16.
    Autoselect works, but no pin is found.
    Is used ioterminal to finish the job!
    Io terminal works great on bcm Opel types.
    For most of the opels without bcm, i used fvdi 2014.
    It can collect pin from ecu. And program keys.
  2. #182
    Jan 2017
    USA ����
    2010 ford mustang GT AKL USA 04/09 date but 2010 VIN number
    fail under all types tried many times to add key or to erase with all programmers under different year groups as well and different models
    X300DP full add key and erase FAIL
    ck200 add key and erase fail
    skp900 add key fail
    ikey820 add key and erase fail
    JOB DONE BY MVP by vehicle
    PATS 6 TIMED - ERASE ALL KEY AND ADD IN 2 AFTER 10 MINUTE WAIT
  3. The Following 3 Users Say Thank You to sleepyrz For This Useful Post:
    HeXeN (15th August, 2018), Krittanu (17th August, 2018), kronk92 (16th August, 2018)
  4. #183
    HeXeN's Avatar
    Mar 2015
    Smart 450 - FAIL no communication
    FVDI - sucess
  5. #184
    autocheck's Avatar
    Feb 2014
    Zimbabwe
    Can Key Master Dp plus do all key lost landcruzer 200 series 2017 Smart key
    Sent from my X5mini using Tapatalk
  6. #185
    drugowaz's Avatar
    Mar 2015
    Lithuania
    From your post ck200 is beating all tools
  7. #186
    hcip's Avatar
    From the heaven of paradise in the middle of happiness|hobby:__Bedtime| Sex:Female|Status:Not_Virgin
    Quote Originally Posted by autocheck View Post
    I tried in LC200 2017 year with smartkey H-type Page1=A8, BH1EW, OBDSTAR XDP give an error "ECU Negative Response" , cannot do AllKEYLost
    Tango+ 6.7 version cannot connect also to a car
    Stupidity is not a disease, because there are no existing hospitals for Idiots!
  8. #187
    Apr 2018
    You mean Toyota Land Cruiser ?
  9. #188
    autocheck's Avatar
    Feb 2014
    Zimbabwe
    Quote Originally Posted by SMP7 View Post
    Yes please
  10. #189
    Apr 2018
    Yes please
    Do not support at present
  11. #190
    rob h's Avatar
    May 2011
    Opel Corsa c 2003.
    Not able to read pin.
    Program with pin ok.
    No function to program remote.
    Code from ecu using fvdi, program remote opcom.
  12. #191
    Oct 2017
    Land cruiser after 09/2017 no sloution yet.
  13. #192
    Jan 2017
    USA ����
    Quote Originally Posted by drugowaz View Post
    out of all my tools it is the one that has made me the most money by far
    ive replaced the keypad twice and the cord once
    and im planning on buying a spare set just in case
    this thing does probably 90+% of what i run into
    i should have started a ck200 thread a long time ago but basically it does almost everything i need it to
    some of the cars i post in here or on the ikey820 thread i know could have been done by the ck200 i just chose to try these out and see if they could do it
    and youll see on some of them in the end i use the ck200 or ill say i prefer the ck200 method or the instructions might be better or something
    its a pretty solid little tool but its old now and getting to take a rest more and more often as its little brothers are getting to play now with the newer systems a little more often
  14. #193
    siyadk's Avatar
    Dec 2012
    can you confirm your verion number in ck200?
  15. #194
    ttzag's Avatar
    digital-kaos
    Today
    Replace ecu with a used one for mazda 3 2008 and program it by x300 pro3........... Ok
    Sent from my HTC U11 using Tapatalk
    Actions speak louder than words
  16. The Following User Says Thank You to ttzag For This Useful Post:
    rob h (30th August, 2018)
  17. #195
    Jan 2017
    USA ����
    OBDSTAR X300 DP PLUS, X300 DP, X300 Pro3
    Chrysler IMMO Update
    Chrysler 300/300C 2004- smart key system (add key/erase key)
    Dodge Charger 2014- smart key system (add key/erase key)
    Dodge Durango 2014- smart key system (add key/erase key)
    Dodge RAM pickup 2002-2005 IMMO system (add key/erase key)
    Jeep Cherokee -2014 IMMO system (add key/erase key)
    Dodge Challenger 2014-/Dodge Magnum 2011- smart key system
    (add key/erase key/key quantity/pin code reading)
