Page 2 of 42 FirstFirst 123456712 ... LastLast
Results 16 to 30 of 628
  1. #16
    smokey08's Avatar
    Essex, UK
    Default X300 Pro3 and DP pad and keymaster DP yes or no fail/success
    2008 Audi A4 rb8 fail.
    Tried to read immo data and it failed and left car immobised with def on dashboard.
    Read + write eeprom ok so was able to recover easily.
    Completed job with other tool so didn’t try any of the other functions listed.
  2. #17
    Jan 2017
    USA ����
    2012 mitsubishi Galant USA AKL
    Fail
    Device only has up to like galant 2006......
    2018 Toyota 4 runner AKL success!
    Bypass security and key programmed in 10 seconds
  3. #18
    smokey08's Avatar
    Essex, UK
    2005 Vauxhall astra H program key ok. Input security code that I had from carpass.
  4. #19
    Jun 2014
    2007 Kia Cee'd , UK. AKL: Failed to pull PIN but programmed key .
    2006 Citroen C2 , UK. AKL: Failed to pull PIN but programmed key .
    Vectra C, UK : No comms.
  5. #20
    coolsoda's Avatar
    Apr 2008
    Scotland
    Failed to read Pin 2014 Peugeot Partner,took so long also went into Economy mode
    Failed to read Pin 2004 Renault Kangoo
  6. #21
    rob h's Avatar
    May 2011
    Quote Originally Posted by coolsoda View Post
    Psa, with or without working key?
    Bsi type?
    Upgraded?
    model runs from
    20xx to 20xx
    Please stop posting like this.
    What are you, the ridler?
  7. #22
    obdsystems's Avatar
    Oct 2013
    U.K, not the E.U.
    X300 Pro3 is 6 months old man so replaced with OBDSTAR X300 DP
    you guys have balls testing china stuff on Citroen n Peugeot
    I am a FUD
  8. #23
    Oct 2015
    Strange about PSA - I have x300 pro3 and during reading pin code for spare key have to only cycle key ignition on/off (I remove key every cycle). Made cars from 2006 to 2014 and till now without problems.
  9. The Following User Says Thank You to klesk1986 For This Useful Post:
    mexanico1971 (5th March, 2019)
  10. #24
    igorr's Avatar
    Aug 2010
    x100 pad 2 only updates for diagnostic,no ford europe key programming big mistake no fem modul no volvo
    and all other companies have that updates
    lonsdor x300 ...
    fail to program smart key suzuki vitara go to dealer to add key,
    fail to program lost key mitsubishi outlander
    so far only peugeot and citroen ok pull pin if you have vorking key
    I dont have x300dp but from I'm readind it is more beather tha x100 pad2 for key programming
  11. #25
    ray-ray's Avatar
    Learn the Chinese game no one unit will work all, when there is a new machine coming out every 2 months. Look at the pass clone t-300 keep getting new update version and no software changes inside just the version number. As the clone gets oldier the pcb keeps loosing more parts. Xtool Pro Pad 2 will have tested software coming out of the USA that I have work on within a year. My contract with them is hold my software for 2 years before they release in china market.
  12. The Following User Says Thank You to ray-ray For This Useful Post:
    igorr (4th April, 2018)
  13. #26
    igorr's Avatar
    Aug 2010
    yes ok in USA but whay then in descriptin is not mentioned tested i usa and australia
    what about europe,whay then they in option give europe cars.
    I dont understand that buisnies politic
    thats same thig I sell my costumer key but I don know will it work or not you can tray it on another model maybe it will work
  14. #27
    lion0304's Avatar
    Oct 2014
    Quote Originally Posted by igorr View Post
    Chinese key programmer, if you use only by name, region in few minutes. So it very hard to know if tool work.
    I alway use various models, region after the first try fail.
  15. The Following User Says Thank You to lion0304 For This Useful Post:
    igorr (5th April, 2018)
  16. #28
    ray-ray's Avatar
    Asia,go under Israel work most of your Mitsubishi.
  17. The Following User Says Thank You to ray-ray For This Useful Post:
  18. #29
    igorr's Avatar
    Aug 2010
    Quote Originally Posted by ray-ray View Post
    do you maybe know will be ford europe implemented for key programming
  19. #30
    lion0304's Avatar
    Oct 2014
    I'll have soon a Transit Custome 2013 to try with X100 Pad2.
    Remote use KeyDiy work well. Transponder try later when customer come back.
  20. The Following User Says Thank You to lion0304 For This Useful Post:
