Ford Fiesta 2006 failed to program
mvp programming no problem
What did the device display when failed?
x300dp.
Continental BSI Q0X 308 T9 2014.
Read pin, eeprom and flash OK.
Writing bsi mileage OK.
Sadly failed to write back the org eeprom, or any other eeprom, from files.
It does write the eeprom, during mileage adjustement.
Why is this?
this is all USA cars
AKL= all keys lost
2008 ford expedition AKL try to program keys under every protocol on the machine in ford and nothing worked so i went over to lincoln and used lincoln navigator 07-08 and had to erase all keys and program back in two keys SUCCESS sort of
2016 ford focus add key incorrect password try to erase keys and got incorrect password again
had to go to asia region ford focus type 2 it pulled some 4 digit pin code and programmed the keys in about 4-5 minutes SUCCESS
2016 ford f150 failed on everything apparently x300 can only do up to 2015 f150..... FAIL
2005 ford five hundred AKL bypass security and erase keys and add back in two new in about 30 seconds SUCCESS
2015 ford mustang smart key add in spare programmed in about 4-5 minutes SUCCESS
2015 dodge ram pod add in pin provided by dealer programmed POD y170 under (13- ram) SUCCESS
2015 chrysler town and country pulled pin and programmed a fobik under (no tooth rotation) SUCCESS x2
2006 chrysler town and country (pacifica system) pin provided by dealer program success SUCCESS
2018 toyota 4runner AKL g chip reset and programmed in about 10 seconds SUCCESS
2016 toyota corolla AKL H chip reset and programmed in about 10 seconds SUCCESS
2015 toyota camry AKL H chip reset and programmed in about 10 seconds SUCCESS
2015 mazda cx-5 smart key add in spare success had to try another protocol and it worked SUCCESS
2015 mazda cx-9 smart key add in spare success had to try another protocol and it worked same as above SUCCESS
2008 chevrolet impala 12 minute wait and program fine SUCCESS
2015 infiniti q40 (49622 remote) 4 digit pin x300 can pull the pin and unlock the steering but cannot program in the new key for some reason FAIL
job completed by skp900 or ck200(ck200 is better at it tho )
2010 nissan altima (49622 remote) 4 digit pin x300 can pull the pin and unlock the steering but cannot program in the new key for some reason FAIL
2012 nissan maxima (49622 remote) 4 digit pin x300 can pull the pin and unlock the steering but cannot program in the new key for some reason FAIL
2013 nissan altima 20 digit bypassed and key programmed in 30 seconds SUCCESS
Have they release the Volvo onto that unit yet & have you tryied it?
im having a bit of an issue there actually ray
i talked to the obdstar rep on skype for about a year now and i asked her where to get the latest tablet with FULL version she said i have a local distributor (UHS)
i said ok so i called them and asked if they had the FULL version of the DP tablet and they said they did (2 or 3 different people said this)
i went on their website and indeed it was listed as full version
they had a sale and i bought one
come to find out it is not a full version it is indeed the standard version
i am currently waiting for a response to what they are going to do
so in answer to your question ray i cant get the volvo software because i dont have the full version............
Yes, Volvo immo is now added.
It is on my X300DP full since last week.
Will look for a customer, to try this function!
How do I find log file?
Also 2016 Ford was flip key I believe
2009 Dodge Challenger under North America Challenger read PIN code FAIL
Had to go under type: no tooth rotation type 2
and pulled PIN code and programmed fobik in 60 seconds
log file how to send
2011 toyota prius smart key
communicates under type 1 but when i go to immo reset
says reset not supported FAIL
job done by ck200 in 16 min
2008 Chevy Malibu AKL
Popped out ignition in 2 minutes
Spent the next 15 minutes trying everything in the menu and it wouldn't connect FAIL
Job done by ck200 in 12 minutes
2009 Chevy Malibu AKL
Remembered last fail and just got ck200 FAIL
Ok here's the info on how to send obdstar the log files
PDF attached
Finally got all the Chinese and europe only stuff off my menu also by digging into file explorer and just deleting folders I don't want to show
Also she said if you could edit the log file by FIRST clicking on the log file and THEN with the pencil try to explain how it failed or what went wrong it will make it a lot easier to fix
Just type it in under "testers notes"
