Hi Folks.
I made a reader that I found http://radiocode.ru/?page_id=424
Attachment 509294Attachment 509295
and can not read nec.
have windows 10 64bits
somebody use this reader?.....
Yes working
I used on the XP
richiebb (24th February, 2018)
installed and tested in Windows XP 32b on the new partition and still does not work.
explanation photo schema:
Attachment 509444
photo of the unit has in Bench
Attachment 509449
Are the connections the same?
Please some help
Try with another MAX232 IC...
ok... i will try... Thanks
Capacitors 10mf?
All capacitors is like in Motocracker
Hi look here
Motocracker(using to read Motorola MCU) also work based on MAX 232.Also Rx,Tx,RST,GND,etc....But this is same shematic.
GOLO your archive is locked
Try this schematic but with software for RCD
in the archive are pictures taken with the interface
the interface is made exactly as in the schematic
is done quickly on a test board
and I do not want collegs on the forum to laugh at me.
please pasword arhive
golo you read NEC from RCD510 whit this conections?:
Attachment 509490
YES ........
If protected you can not read
