Central heating technician help please.
Results 1 to 12 of 12
    super jumbe's Avatar
    Dec 2008
    Livingstone
    Default Central heating technician help please.
    Vaillant Ecotec Pro 24 plus goes to F28 fault code after 4 hours.
    Any one can help I have got Vailliant combo boiler, the boiler will stop working when not in use at night or left not used for 4 hours and once reset the boiler will run all day without stopping.
    The boiler will only stop working when hot water is not used for over 4 hours any idea?
    Thanks in advance.
  2. The Following User Says Thank You to super jumbe For This Useful Post:
    rosemartine (11th September, 2019)
  3. #2
    ifred's Avatar
    Jun 2010
    google
    "Common Fault 3: Codes F27 & F28
    These codes refer to a frozen condensate pipe, meaning the condensate waste cannot run to the drain and is trapped in the boiler, causing the boiler to lock out.
    The Fix: You may have to wait for the condensate to defrost. If the pipe runs outside, pour hot water over the pipe to defrost it, or place a bucket under the boiler and disconnect the plastic waste pipe on the far right of the boiler, before draining the condensate into the bucket."
    Cold weather - condensate drain pipe freezing need to insulation wrap the outside pipe or trace heat it if it freezes boiler will refuse to start that's your first port of call
  4. The Following 2 Users Say Thank You to ifred For This Useful Post:
    Meat-Head (28th February, 2018), super jumbe (28th February, 2018)
  5. #3
    Dec 2008
    Livingstone
    I first thought of that it was the pressure switch faulty replaced with new one all working good, thanks for your time mate.
  6. The Following User Says Thank You to super jumbe For This Useful Post:
  7. #4
    Meat-Head's Avatar
    All condensing combi boilers since 2004 do this, in emerica you buy heating wire for the waste pipes.
    also if your buying boiler get stainless internals not aluminum as they corrode
  8. The Following 4 Users Say Thank You to Meat-Head For This Useful Post:
    albertros (5th March, 2018), ifred (1st March, 2018), pulsar2000 (30th January, 2019), super jumbe (14th April, 2018)
  9. #5
    ifred's Avatar
    Jun 2010
    Ah yes the FFing Pressure relief value, cheap crappy flap valve that fail for a past time only a few quid and loads of spondoolies to have fitted??
    Bet your glad its sorted
  10. The Following 2 Users Say Thank You to ifred For This Useful Post:
    Meat-Head (4th March, 2018), super jumbe (14th April, 2018)
  11. #6
    Mar 2018
    yes, I do it and it runs.
  12. The Following User Says Thank You to mikimagon For This Useful Post:
  13. #7
    Meat-Head's Avatar
    Quote Originally Posted by mikimagon View Post
    Thats a great idea for everybody, except SJ, as the condensate is apparantly
    corrosive. We would then have another thread entitled
    "help, condensate corroded bucket, gone through carpet, floorboards, artex celing, dripping on to black cat on chippen dale chair below"
  14. The Following User Says Thank You to Meat-Head For This Useful Post:
  15. #8
    ifred's Avatar
    Jun 2010
    Quote Originally Posted by Meat-Head View Post
    As of today SJ is still posting so I guess meaty your forecast is wrong! SJ has NOT added himself to the Celebrity death watch by corrosive means
  16. The Following 2 Users Say Thank You to ifred For This Useful Post:
    Meat-Head (4th April, 2018), super jumbe (14th April, 2018)
  17. #9
    Aug 2019
    Scotland
    Condensate can cause a lot of damage. My elderly parents had to fork out £17k after getting new heating installed three years ago for free, paid for by the government as they are in their eighties and the boiler was more than 20 years old. problem was the plebs that did the work ran the condensate pipe under the kitchen floor and connected it to the drain under the sink but nicked the pipe so condensate leaked for three years into the floor. all joists in kitchen and half of sitting room had to be replaced and new kitchen units. the joists that came out felt like rubber.
    these things are great for freezing condensate pipes. they store the condensate until the little tank is full and and let it go all at once. the little tank clips around the heating flow pipe so the condensate is warmed up as well.
    http://www.leagrave.net/product/1064...iliary_siphon/
  18. The Following User Says Thank You to Dwarfer For This Useful Post:
    Meat-Head (23rd August, 2019)
  19. #10
    Meat-Head's Avatar
    Nice post, somebody we know “Penis Peterson” mentions putting some lime or something at bottom of pipe
  20. #11
    Feb 2020
    USA
    You must shut down your archos, and than switch the power button on lock position. With the rkandroid methode it must work. Be patient on win7 system and wait to install the drivers.
  21. #12
    Feb 2020
    Condensate pipe frozen or blocked.
