Page 2 of 7 FirstFirst 1234567 LastLast
Results 16 to 30 of 94
  1. #16
    rob h's Avatar
    May 2011
    Just finished, i updated mine, with the UpdateNew.bin file.
    All looks well, whent from a few tokens left:
    Took about 1hour.
    Not plugged it in to any car, but it looks fine!
  2. #17
    Jun 2016
    Quote Originally Posted by aassfour View Post
    I ve got a word from a chinese friend that SKP900 Server is off , no longer will support add tokens which will result in a dead tool.
    so i tried to add tokens on 3 SkP900 , tried multiple connection and different laptop , it says Server no communication.
    if anyone can confirm this , please try the add token software
    I have a mega link which can release the SKP900 tokens limitation, after using it you can always use the tool.
    https://mega.nz/#!QMxAzRQL!YpdLbhw_p...eVCh53oApc34jo
  3. The Following 4 Users Say Thank You to crazylou2017 For This Useful Post:
    Fernandowap (1st April, 2018), Rachon (11th March, 2018), Stelaras26 (12th March, 2018), ybot (2nd March, 2018)
  4. #18
    rob h's Avatar
    May 2011
    Thanks Crazylou2017, do you have a key for this file?
  5. #19
    Jun 2016
    Quote Originally Posted by rob h View Post
    no password for this file. thanks
  6. #20
    Sep 2010
    I also update SKP900 with little file, and for now looks OK.
  7. #21
    Oct 2017
    Gents here's the file for those with 0 tokens already.
    http://www.mediafire.com/file/cnnys5...jbg/SKP900.zip
    Sent from my ASUS_Z00AD using Tapatalk
  8. The Following 6 Users Say Thank You to djjazzer For This Useful Post:
    Fernandowap (1st April, 2018), Jobeso66 (18th June, 2018), PocketHero (11th March, 2018), Stelaras26 (12th March, 2018), Troco5773 (18th February, 2024), ybot (2nd March, 2018)
  9. #22
    Thanks to all for this thread, works great with little file, had a few tokens left when updated.
  10. #23
    auto techniek's Avatar
    Mar 2017
    If you update you loose token if you still have?
  11. #24
    newone's Avatar
    Oct 2016
    Quote Originally Posted by auto techniek View Post
    there is a token counter,when is under 10 skp gives you message to update tokens,do not wait to go to 0,just use the little file and everything will be ok
  12. The Following User Says Thank You to newone For This Useful Post:
    auto techniek (2nd March, 2018)
  13. #25
    Jun 2016
    germany
    Hi @ all,
    my SKP still has 9 token now. I have tried the updater, but unfortunately without success. Every time I get the message "COMMUNICATE FAIL!"
    I tried Windows XP, Windows 7 and Windows 10 on three differnt Notebooks. USB serial port with FTDI driver should be ok. I changed the com port a few times.
    When I plugged in the SKP, the updater shows the correct com port.
    Does anyone have any idea what I could have done wrong?
    Buntbart
  14. #26
    rob h's Avatar
    May 2011
    Dont choose token menu, choose function update menu
  15. The Following 2 Users Say Thank You to rob h For This Useful Post:
    buntbart (2nd March, 2018), dave11674 (3rd March, 2018)
  16. #27
    Jun 2016
    germany
    Success with Windows XP after reinstalling the FTDI driver from original CD and playing with the com port settings.
    I don´t know how and why, but now it's token free.
    Many thanks to all who help to keep the SKP alive.
    I use it often to programm VAG remotes.
    Buntbart
  17. The Following User Says Thank You to buntbart For This Useful Post:
    piticulto (4th April, 2018)
  18. #28
    Oct 2017
    Default Final files from SUPEROBD for SKP900
    Here is the sloution for 0 token and more than 0 token.
    i am attaching both files.
    Regards,
    Asif
  19. The Following 9 Users Say Thank You to Asifmehmmod1 For This Useful Post:
    aassfour (3rd March, 2018), ascotauto (6th March, 2018), gkinz (3rd March, 2018), godfathertre (3rd March, 2018), PocketHero (11th March, 2018), ROMIR (22nd March, 2018), Stelaras26 (12th March, 2018), triak88 (5th March, 2018), Weasel3 (3rd March, 2018)
  20. #29
    Apr 2015
    Hello i you are using the update exe2.5 that came with this update file will not work use the older update tool 2.4
    If you don’t have go to theyre website and you can find it
  21. #30
    dave11674's Avatar
    Florida, UK
    so to get this right guys
    out skp900 has to be on version 5.0 yes ?
    then update with this littlefile
    dave
    Tools owned.
    AVDI commander.
    Dashfixer orig.
    Dashfixer clone.
    Fiat km tool.
    Opel km tool.
    Ford KM tool.
    Op--com colne.
    Lexia & PP clone.
    Smok PSA, volvo & ford
    If someone helps you DONT FORGET TO SAY THANKS its only polite....
