Page 4 of 7 FirstFirst 1234567 LastLast
Results 46 to 60 of 94
  1. #46
    Nov 2010
    can I have the same problem, I use somes ftdi but very time I get the message "COMMUNICATE FAIL.
    You have Idea??
  2. #47
    Feb 2015
    ireland
    Hi I have been offered a used skp 900, has any one managed to load tokens to his or is it dead.
    thanks for any help
  3. #48
    rob h's Avatar
    May 2011
    Quote Originally Posted by westlock View Post
    thanks for any help
    The solution works!
  4. #49
    seems like the solutions dissappeared can someone help me please...pm me
  5. #50
    newone's Avatar
    Oct 2016
  6. #51
    newone's Avatar
    Oct 2016
    Jun 2017
    US
    Had one token left on mine, used little file, can now go into functions that do a token check over and over and doesn't ask about tokens. Will try to use in the field as well to make sure still good.
  8. #53
    Oct 2017
    Funny thing happened today. My SKP said I had 0 tokens. This is AFTER I had solved the token problem over a month and a half ago. And now loading same files again, do not work. Anyone else?
    Sent from my ASUS_X018D using Tapatalk
  9. #54
    vsanyi's Avatar
    Aug 2012
    Hi!
    My skp900 even after the upgrade 0 tokken.Any idea?
  10. #55
    i try to connect to pc no succes
    why pc and loader not connect
    i changed also FTDI chip
    helppp
  11. #56
    Nov 2015
    UK
    Please advise what you mean about token check ?
    Is this something new as never seen this mentioned before.
    Thanks.
  12. #57
    Any solution for this zero token problem yet? Already tried both the little and large update
  13. #58
    Nov 2015
    UK
    It’s unbelievable that they supply 2 files that nobody is really clear on which to use or even be able to check.
    I think if it was made more clear, also actually worked then all users would be happy.
    You can even check how many tokens are on the unit.
    Absolutely pointless.
  14. #59
    hass42's Avatar
    Aug 2012
    USA
    I see this files have been deleted for if you have zero tokens already.
    so if you have zero tokens, need to upgrade to 5.0, if already have 5.0 then use 5.0 lite to remove token
  15. #60
    Nov 2015
    UK
    You mention 5 lite.
    What is 5 lite ?
