Page 1 of 7 123456 ... LastLast
Results 1 to 15 of 94
    aassfour's Avatar
    May 2013
    kensington
    Default SKP900 Server Down Dead no more Tokens
    I ve got a word from a chinese friend that SKP900 Server is off , no longer will support add tokens which will result in a dead tool.
    so i tried to add tokens on 3 SkP900 , tried multiple connection and different laptop , it says Server no communication.
    if anyone can confirm this , please try the add token software
    The only place success comes before work is in the dictionary.
    auto techniek's Avatar
    Mar 2017
    Does this means that the tool is worthless?
    rob h's Avatar
    May 2011
    It has been down before.
    The tool is still available, so it might just be temporary.
    Not all functions requier tokens. They should release a token free version, V5.0.1
    I dont think that i will gamble on the skp1000 or Lonsdor either, until there is a permanent fix.
    Best to contact your dealer, and let them sort this with the manufacturer.
    aassfour's Avatar
    May 2013
    kensington
    Quote Originally Posted by rob h View Post
    all functions needs token on this tool, plus the server has been down for couple of weeks now. if it temporary its a long period. tried to contact superobd : NO ANSWER
    i already have lonsdor x100 mvp and other tools so its not a problem for me. but i m sure many has only skp so they will have a problem if its TRUE
    newone's Avatar
    Oct 2016
    you are right,they must at least post a token free update as any more updates will be a dream for this
    rob h's Avatar
    May 2011
    I can confirm, that the updating does not work.
    Just tried it,
    I have contacted my suplier,
    Mar 2017
    I ve tried to contact them.
    Email was rejected and not received.
    Feedback form does not work.
    Skype no answer.
    They still celebrating new year I think
    rob h's Avatar
    May 2011
    Did you buy direct from superobd?
    aassfour's Avatar
    May 2013
    kensington
    i bought directly from superobd i was a seller , now i have 4 SKP no tokens from various customers ,
    all china came back from holiday so i dont think they are celebrating
    i m afraid the rumors are right
    Oct 2017
    I can confirm as well, the device is not communicating with the server to activate new tokens...
    Sent from my ASUS_Z00AD using Tapatalk
    Jun 2017
    US
    I updated mine about 4-5 days ago. Was going to do a packet capture on the exchange with wireshark but have been super busy. Well this sucks, if it goes back up I'll try to make it a priority.
    Edit: Wonder if when you do a firmware update if it will reset tokens? If the servers are down for good and they don't come back in a week or two I'll crack mine open and see if there is an eeprom on it or if there is an Atmel than we can read from with SPI. Maybe it'll not have the bitlock set and we can edit it.
    Edit2: Well got anxious and don't have much to do right now so cracked her open. The important ic's are surface milled so have no identifying numbers.
    Looking to try to see if this chip can be read via SPI or JTAG. Looks like it has a breakout for a header to do this, but not sure what chip it is. Asked on reddit if anyone can help identify the pinout. Anyone here familiar with Atmel AVRs? I don't think it's a cyclone chip.
    Also any guesses what the chip below it could be ic10? I know the IC8 is likely a nand or nor chip. My guess is the token count is stored in the chip with the spi or jtag breakout.
    https://imgur.com/a/4LkoX
  12. The Following User Says Thank You to darknezz19 For This Useful Post:
    rob h (1st March, 2018)
  13. #12
    Oct 2017
    Ok got this info from my boys at uobdii
    http://www.mediafire.com/file/hmscik...l%20tokens.zip
    Use the V5.0 Little File in this zip to flash your device, then it will be token free. Note it has to be V5.0 version.
    Didn't work for me though as my device is already at 0 tokens, hopefully works for devices still with tokens available.
  14. The Following 10 Users Say Thank You to djjazzer For This Useful Post:
    darknezz19 (1st March, 2018), gazzaull22 (1st March, 2018), mikajna (9th September, 2018), newone (1st March, 2018), PocketHero (11th March, 2018), rob h (1st March, 2018), servicekey (1st March, 2018), Stelaras26 (12th March, 2018), triak88 (2nd March, 2018), Weasel3 (1st March, 2018)
  15. #13
    aassfour's Avatar
    May 2013
    kensington
    Quote Originally Posted by djjazzer View Post
    i just did it , but didnt work my tokens were 0 as well
    in fact the screen crashes after i press YES
  16. #14
    Apr 2017
    I have active skp900, so I do little update and it's ok for the moment, I will give feedback later, I don't know how I can see if tokens is stable?
    regards
  17. #15
    we had x7 tokens left
    tried this update file
    all loads up fine and not showing that we need tokens now .
  18. The Following 3 Users Say Thank You to gazzaull22 For This Useful Post:
    mkopytekchi89 (19th November, 2022), rob h (1st March, 2018), servicekey (1st March, 2018)
