If the developer released this themselves.
When the tools stopped updating and selling.
I will give them full credit, for doing this gesture.
That is a responsible developer.
updated mine had v 5 only took one minute still had over ten tokens does this file works for over ten token or do you need to wait you have less than ten token before using the
file thank you .
How to see how many token do I ve?
auto techniek (4th March, 2018)
Im glad I came across this forum. I will try to update mine. thanks for the help guys
PLease try again i tested files on my sites.its downloading.
i get the don't have permission screen
reflashed mine all gos ok tested in one car no problem but wen try other car go to wihte screen , befor cant update intill i activate update from skp naw cant activate it from skp 'white screen ' sow no connection again , anny solution ? also the old dump for repaire screen cant find it anny more can some one provide please ?
thank you.
OK, I installed the "little" file a few days ago and thought it was good but now says no token.
Try the file Asifmehmmod1 posted?
http://www.digital-kaos.co.uk/forums...=1#post3229875
Let us know if you or if anyone has tried his with 0 tokens.
Yes, There are 2 files in that zip and I tried the "little" first. I have since installed the other one "all" as well but no change. Then I re-updated to V5 main software and tried again but still no success.
Ok, I met once such problem when I want to install 5.0 Sounds brutal, but works: Install 4.5. Begin to install v5.0. After 50 mins just pull out the usb, and restart SKP. usually it tells ya @ boot that the 5.0 is installed. Now update it again, and it'll work
Mine said 2 times use remain. Reflash with little file. Took 2 minutes.
Tested on RAM1500 2012 read pin, add key succesful. SKP900 doesn't said anymore about time using.
Hola, tengo el problema con skp-900,
Me pone que tengo 0 tokens y esa actualización, pero no lo entiendo, tengo la actualización V5.0.
Haber si puedes ayudarme, saludos.
