Page 3 of 6 FirstFirst 123456 LastLast
Results 31 to 45 of 76
  1. #31
    I don’t understand why Mr.brend is so critic about me.
    I told that you can read and write with AVDI without any problem and our friend James make it successfully as I stated.
    To make mileage convert your mileage in hex and then make 2 bytes checksum by base complement.
    I give you another news. This dash does not have any 95160 eeprom inside, this is why AVDI read until certaing %.
    Do you need any other explanation ?
    Bests
  2. #32
    brend's Avatar
    Oct 2015
    Same where
    Relax mate..!
    Its not critic.
    Just I try anderstand how and what.
    And how work with this dump from james44000 no more.....
  3. #33
    You can push the thanks button if we helped you Mr brend
  4. #34
    marina_rv's Avatar
    Ukraine
    Quote Originally Posted by james44000 View Post
    I try to read eprom it stop at 32%.
    in dash no ext. eeprom, km in MCU = MB96F6A6.
    Master history : ...2004 - only NEC, 2004....2010 - eep 93C66, 2010...2013 - eep 93C76, 2013...2015 - eep 95160, 2015..... - only MB96F6A6.
    please press the little THANKS
  5. The Following User Says Thank You to marina_rv For This Useful Post:
    brend (22nd October, 2018)
  6. #35
    You are right but eep 95160 is emulate by mcu ( virtual eep) on last master 2015+
  7. #36
    Default Renault Master calculation
    Hello Paskuale, Would you be able to adjust this renault master 2018, Its read by avdi 32% file. Need 28123kms please, Ori is 46222, Thanks for your help. Edmundo
  8. #37
    Your file attacched.
    Write it, it will stop at 32%. No problem, it will work.
    Bests
  9. The Following User Says Thank You to paskuale For This Useful Post:
    Edmundo (24th January, 2019)
  10. #38
    Worked perfectly, thanks again
  11. #39
    Feb 2016
    cheksum bytes = ffff - mileage not swapped
  12. #40
    DK Veteran kams20040's Avatar
    so what about abs ?
    no need to do ?
    dont understand ?
  13. #41
    No need to correct ABS.
  14. #42
    I need to change the mileage.
    Master Fujitsu MB96F6A6.
    Fvdi 95160 reading 32%.
    Current 174621 ml.
    Need 73900ml
    Regards.
  15. #43
    jomberykaso's Avatar
    Sep 2013
    En algun lugar de Chile
    Do it as kangoo
  16. #44
    It doesn't work through kangoo
  17. #45
    Sep 2013
    i mean, the same algorithm mate
