I'm putting this file here just to put it here. I will say that we had a hell of a time removing the needles on this cluster. Best way was to apply heat using a heat gun at 100C . Even then it was still hard. Chip is a 24C32
Hope the picture help. If anyone has any other way of getting to the chip, via traces please let me know. Damaged one of the motors trying to get them off originally.
Don't forget to thank me if you like Any questions I'll try to answer them. I used DSP3+ to set it.
use a multimeter? hold one end to first pin of chip. then check all connections with other end of multimeter on the other end of the board, see if you get a match. then check the other pins
Nicolas9 (28th February, 2018)
What is the mileage in the dump?
i bet its 3088miles
- Remember Don't Just Sit There In Boredom, Add to the Forum!!
DashProg (2nd March, 2018), zckariya70 (2nd March, 2018)
Like 3000 something. This is a damaged cluster that we're using to test the disassembly of it. The pointers don't come off by twisting it and popping it off. Seems you either have to heat the pointer so it soften the plastic so it slides off easily. Or pry on it like a 500 pound gorilla.
These engines have a trick of removing the needle, you do not need kilos of force ...
WINNER THE LOSER
drpeter (3rd March, 2018)
Nicolas9 (6th March, 2018), zckariya70 (6th March, 2018)
Indeed there is connection...
Only bug is that it goes from the 24C32 to processor only
I done it but had to change the speed stepper motor after...
Pin 6+7 from counting from right side...
Live by the rules and die by the rules...
Thank before you die...
