Results 1 to 8 of 8
Thread: clone bsi ecu
    Jan 2018
    Default Help please
    hello ,please i need help
    1) how can i change pin code in BSI ECU for ( VAG ,Peugeot/Citroen) ?
    2) i have seen smok products , what you think ?
    thank you so much
    raceshadow's Avatar
    Mar 2016
    Czech Republic
    I use Carprog.
  3. The Following User Says Thank You to raceshadow For This Useful Post:
    Aliben (1st March, 2018)
    Feb 2017
    UK
    replece eeprom from your bsi to new bsi and pin will be the same
  5. The Following User Says Thank You to jacekzam78 For This Useful Post:
    Aliben (10th March, 2018)
  6. #4
    Jan 2018
    but i want to know , how to do it without desoldering
  7. #5
    Apr 2017
    is it possible with dashboard vw ? THNAKS
  8. The Following User Says Thank You to musta2007 For This Useful Post:
    Aliben (11th March, 2018)
  9. #6
    Jul 2016
    Reunion Island
    Quote Originally Posted by Aliben View Post
    thank you so much
    hello
    to change pin in PSA BSI, i think you have to virgin your eeprom dump then recode with pps/lexia (Coding + Immo adaptation(PIN) + Key learning)
    or
    You can clone your BSI with smok, avdi or ioterminal (Read FLASH and EEPROM in old bsi , write them in donor) (not all bsi are supported)
    sometimes need to key learning after cloning
    SMOK is very good tool (you have to spend money for it)
    i don't recommend eeprom swapping , works for old bsi but on others strange behavior
    For VAG
    you can change pin in dash - ECU (adaptation with VCDS Immo2 - Immo3(no sure))
    from Immo3+(Dash) / Immo 4(Dash) / Immo 5 (cars with key in BCM2)
    you have to adapt with CS , MAC , PIN , POWER CLASS in the donor DASH - ECU (not Immo 5)
    VVDI , AVDI , SMOK good tool for the job
    hope you find some help in my answer
    Best Regards
  10. #7
    Dec 2009
    uk
    hi ya on psa we just swap two 95 eprom from old bsi and code bk with car pass
  11. #8
    Dec 2009
    uk
    have to be same partnumber letter on the end don't mater
