Results 1 to 5 of 5
    Jan 2014
    Default plz help nissan ud escot fault
    hello to all my client did the gearbox on his nissan ud however after refitting everything theres a escot fault on the dash i tried to use delphi to diagnosis the fault on the transmission but was unable to no software can someone please advice me on how to repair this kind of fault also claimed something about low air pressure thank you
    Jan 2014
    air pressure is
    escOT insufficient gearbox brake mechanical error,,,,transmission tank air pressure,,,,,,,clutch system faulty frequency
    Jan 2014
    solved if any1 needs help pm
    May 2022
    Malawi
    Quote Originally Posted by Mr Mo View Post
    I have almost same problem in us Nissan truck it's writing escort system malfunction,how do I solve this problem
    Jan 2024
    Hi I’m haveing the same issue with my UD, escot light just keeps flashing and can’t select gears. Any idea?
