hello friends i got 2 Ford edge 2017 all key loss i program for the first one 2 keys using Lonsdor k518ISE with success but the second one it have Hazard light with alarm sound maybe they try to program it before using another non compatible programmer and the alarm is on and Lonsdor cant connect
any idea how to exit security mode to can connect ?
cyril (12th March, 2018)
yes it have door code but i dont have it and how can i know of the screen is ready pls ?
Try to program it with CK100. I succeed to do a '16 Flex smart key with it.
From other hand I can't understand why the Lonsdor didn't do it, maybe you have to try different model an year. I do lots of American sportscars, and never had problem with the alarm system. Maybe it was running, but i could do the programing and then switched off the alarm with the remote.
Amazing how something like CK100 = “TKO ilco” that was clone back in 2012 can program a new rolling code 2017.
no chance of ck100 working
and espcially if it had hitag key
Try this procedure from mustang 2015 https://youtu.be/bciy-6749_g
p1et (19th March, 2018)
Ok, my fault, it works only til 12.
*sinking into the ground emoticon*
2014 Fusion can be program with the alarm active, 2015 “Can Blocker” will not let you communicate with the immo.
So what is solutions in all keys lost if can blocked?
Renault ECU tool / IO terminal / A.S.W
If there a door keypad, remove the module near door plier. The module will have the 5 digits.
https://m.youtube.com/watch?v=pR709EMjZvA
I tried skp 900 did not do it, I programmed MVP pro
fang, Narwalus microcephalus,Spectrum Zx, Atari amiga, Commodore +4
