Results 1 to 3 of 3
    Nov 2017
    Default Renault megane3 2012 1.6 74kw
    Hello. This car do not start. Starter stop cranking after 2 seconds. battery was empty. I change battery and I found blown alternator fuse, change it, but no luck. In engine ecu is some memory faults and I can not erasing these faults. If I disconnect and connect back engine sensors, faults retains and not erasing. I try erasing with renault clip. Also live data shows imobilizer active, but no faults about immo...
    Somebody knows how to erase memory faults in this car?
    Is better post the faults you readed and check ecu connections.
    eepromdom's Avatar
    May 2017
    Based in villieria, Pretoria. South africa
    Quote Originally Posted by darius211 View Post
    Pls post a pic of ecu Part no... Then ill tell you what processor info to send.. Serial or flash.... I have ecu immo off solution..
    Sent from my LG-H850 using Tapatalk
    no passwords here..i aint trolling for a gold star.. love this forum
