Results 1 to 4 of 4
    Mar 2018
    Default Iveco Daily OBD To 38Pin??
    Hi guys
    I'm trying to find a cheap Iveco OBD to 38pin cable but i'm a bit stuck and could really use your help.
    I've read on here that i should make sure tat the cable says it "Fully Wired" to make sure it can also read ABS, Airbags...etc
    I've found some that state this but then when i ask for the wiring diagram/pinouts i either get this:
    Or this:
    Are any of these any good?
    Mar 2018
    Are any of the above cable any good or should I be trying to find one with these pinouts?
    eobd ----------- 38 pin
    1 ------------ 1
    2 -------------- 2
    3 ----------------- 3
    4 ------------------- not used
    5 ----------------- 30
    6 ------------------- 6
    7 ----------------- 8
    8 ------------------- 10
    9 -------------------- 6+2 together
    10 --------------------- 13+18 together
    11 ------------------------ 14+23 together
    12 ------------------------ 15
    13 ------------------------ 16
    14 ----------------------- 4
    15 ------------------------ 5
    16 ----------------------- 27
    Jul 2013
    yorkshire
    I tried a few, i even borrowed a few, but non worked. TEXA was the only way.
    Mar 2018
    Quote Originally Posted by autoden View Post
    I think a lot of it is down to the program your using to read it.
    I've read that they can be scanned with a "fully wired" adapter, im just trying find one that has the correct pinouts as a lot if them seem to be wired for Mercedes.
    What cables did you try?
