Page 2 of 2 FirstFirst 12
Results 16 to 24 of 24
  1. #16
    Jun 2013
    Original key is working well on remote? Only new one with problem.
  2. #17
    kiszka's Avatar
    Reality of life :
    1:Never argue with an idiot, he will pull you down to his level and overcome you with experience
    2:Envy is the confession of inferiority
    3:Everyone lies
    How much trash you leave behind so much trash someone will have to read or maybe you yourself
    If you like reading garbage, don't slow down, just speed it up
  3. #18
    Oct 2016
    Scotland
    Quote Originally Posted by kiszka View Post
    key number 5 in eeprom does not exist
    That is because this is original dump backed up before doing any work. Then i programmed new key by OBD in VVDI2
  4. #19
    Oct 2016
    Scotland
    Quote Originally Posted by dijo View Post
    Ok, I got it... your first post with "eeprom cas ori" is your first read and untouched about new key...
    In this dump only key nr 4 is bad!!!
    That file that I send you is good!
    At this point I dont know which old key is working for start and remote function...
    If your problem is only your new key where remote is not working...
    Than...
    Is it a 868MHz remote?
    Post your dump with Key Nr5 programmed by you and also Hitag image of this Key...
    Customer doesn't have any remote key just now, so cannot determine that way if it is a key fault or fault on the car.
    As they only have the simple transponder key and not remote, i would hazard a guess it is key ID#1 (PCF 7936), the other keys indicate as remote type with PCF 7942/7944.
    Yes, with new key only remote not working, yes it is 868 MHz.
    Ok, i can arrange to take dump with new key.
    Quote Originally Posted by Weasel3 View Post
    This is from the first dump you post.
    In VVDI2 it starts from 1-4 -- Key number 4 here says PCF7953 and error message pop up.
    In Tang it start from 0-3 -- Key number 3 here says PCF7945 and here it opens without error message. Says E60 old type, 868Mhz
    The other keys are the same in both tools.
    Number 4 in VVDI2 is number 3 in Tang.
    Maybe you could try to read it with a different tool. Or use the transponder programmer function in VVDI2. Out of BMW, and start program.
    Test with KD if you have. Tested with a CN key. Got frequency 868Mhz FSK need to test several times to get result.
    It started as low as 315 then 434 and then up to 868 on China key.
    I read eeprom with one tool (only as a backup if the s**t hit the fan & wasn't used to program the key), then used other tool to program new key by OBD independently form the backup.
    I tried load the dump (even repaired dump) into transponder programmer function in VVDI2 and again get some error.
    Before sending key i checked remote was transmitting, using key tool and CN900. With VVDI2 yes frequency detected seems to change depending on how you hold the key to the tool.
    Can these aftermarket keys be unlocked again / renewed or only OEM?
  5. #20
    dijo's Avatar
    You can only renew OEM keys!
    I use only OEM keys, for this reason cant say anything about your key, but take one image from Hitag of your key...
  6. The Following User Says Thank You to dijo For This Useful Post:
    WRX 14 (13th March, 2018)
  7. #21
    Oct 2016
    Scotland
    Customer doesn't have any remote key to test, otherwise could more easily know if it's a car problem or key problem.
    They only have key like attached photo
  8. #22
    kiszka's Avatar
    Reality of life :
    3:Everyone lies
  9. #23
    Oct 2016
    Scotland
    in the module it is the key in place 0 PCF7936
    Yes, i would say it's that key only transponder PCF 7936.
    Like i mention before, both keys start car ok, new key remote not working and the vehicle downs;t have any other remote to know if problem with receiver etc.
  10. #24
    kiszka's Avatar
    Reality of life :
    3:Everyone lies
