Results 1 to 9 of 9
    Stelaras26's Avatar
    Nov 2017
    Skyrim
    Default Vauxcom version 160115a
    This version 160115a is for high quality clones..
    Has until Astra K inside.
    Mine has good chip inside,firmware 1.70 and works well!
    english language.
    Added firmware/ocflash/cdm uninstaller in txt
    My 1.70 DUMP too
    SO i figured out that you have to use the flashing utility with this good dump,
    ->then your device will be recognised as OPCOM V2 ,and if its a good quality device,
    ->then you install the software,and be carefull to install the correct drivers.
    ->Thats the hard part,because,software opens only if you have the correct drivers installed.
    I did it to 3 devices today,two of them worked fine.
    Pass is : Stelaras2018
  2. The Following 17 Users Say Thank You to Stelaras26 For This Useful Post:
    asliyucegsm (23rd March, 2018), ecufix (14th March, 2018), GianniNOS (15th March, 2018), jakuza (24th March, 2018), janusz21 (14th March, 2018), jif (14th March, 2018), Meat-Head (27th June, 2018), MRAWZIN (14th March, 2018), mylus (23rd March, 2018), saysso (21st March, 2018), sevid (14th March, 2018), sitolek (13th June, 2018), Stefanrs4 (12th May, 2018), subas (1st August, 2019), tomxx (24th March, 2018), tourettes (27th March, 2018), waldigsi (16th June, 2020)
  3. #2
    Mar 2016
    Can I use it with old version '' 120309a+131223d '' ?
    alexandrosts's Avatar
    Feb 2017
    there where civilization started
    this works with the Chinese ? the ebay op-com
    Junior Member tango5's Avatar
    In the neighborhood
    No works with standard chinese clones, do no try you bricked your interface!!
    Only work with "HQ" clone devices.
  6. The Following User Says Thank You to tango5 For This Useful Post:
    Stelaras26 (3rd April, 2018)
    where can i find firm 1.70
  8. #6
    Stelaras26's Avatar
    Nov 2017
    Skyrim
    Here is my dump...
    Use it on your own responsibility.
  9. The Following 2 Users Say Thank You to Stelaras26 For This Useful Post:
    marmaro (3rd October, 2019), sitolek (10th June, 2018)
  10. #7
    EARTH
    be careful . even good interfaces die.
  11. The Following 2 Users Say Thank You to datapage For This Useful Post:
    Stelaras26 (2nd June, 2018), tomxx (10th June, 2018)
  12. #8
    Mar 2018
    Coud you please upload the dump file again?i can't downloaded
    Tahns
  13. #9
    May 2018
    I write PM to You Stelaras but you have full message box
    Can you send me your firmware 1.7?
    Cause i change my ftdi to hq, but i dont have a firmware 1.7... I trying all day hack newest soft in assembler but i dont have a lot of time so i cant to do this, but in my opinion when i use your firmware, the opcom 15 start running
