Results 1 to 10 of 10
    Jun 2016
    Default HotStart FIX needed LEON2 1.9TDi BXE EDC16U31/34
    Hello, could SB fix maps of hotstart in this file ...
    Car Seat LEON
    Engine 1.9TDI BXE
    ECU : Bosch EDC16+ U31/U34
    xCata's Avatar
    Oct 2017
    Try these one and report.
    no pass
  3. The Following User Says Thank You to xCata For This Useful Post:
    pawel7924 (14th March, 2018)
    Jun 2016
    I will check it tomorrow. thx
    Jun 2016
    Your file didn't resove problem. Car didn't start correctly when it was hot ... same as original...
    anybody could help ...?
    maajkii's Avatar
    Mar 2017
    Poland - Sława ( Lubuskie )
    Quote Originally Posted by pawel7924 View Post
    Car Seat LEON
    Engine 1.9TDI BXE
    here you go, no pass
    if thats not help your problem isn't " hotstart problem " but maybe fuel, or engine starter...
    DSG TUNING
    File Service
  7. The Following User Says Thank You to maajkii For This Useful Post:
    pawel7924 (16th March, 2018)
  8. #6
    Jun 2016
    on cold engine start 1 starter rotation .. on hot ... 4-5 rotation ...
    I will check your file tomorrow. thx
  9. #7
    Vasily.U's Avatar
    Belarus Minsk
    You do not know what is "hot start problem")))
  10. The Following 2 Users Say Thank You to Vasily.U For This Useful Post:
    maajkii (16th March, 2018), xCata (16th March, 2018)
  11. #8
    Jun 2016
    i know ... on hot engine fuel injections are smaller than cold ...
    if engine hasnt compression or other ... with smaller fuel dose have problem with start ...
    thats the reason that starter must work more to start engine ...
  12. #9
    Vasily.U's Avatar
    Belarus Minsk
    "hot start problem" when there is no injection at all until the engine develops certain revolutions.
  13. The Following User Says Thank You to Vasily.U For This Useful Post:
    unnamed11112007 (16th March, 2018)
  14. #10
    Jun 2016
    thx for explain Vasily.U ... second file works better on hot 2-3 engine rotation - make start ..
