is the problem only that it dont show gears ? do it drive? did you change something? fault codes?
after change clutch and when after switch on no show gear . no fault code. i think ecu because i try to make adaptation but not respond
i have two read files but from Aygo i beleive they are same mmt- if you want ask me will upload
you can check relay for mmt under front bumper near left bulb
Im here to help and to be helped
yes please send me .. i check it the relay
here mmt two files from one car - new one is from second hand ECU mine was burned
asio15 (3rd July, 2019)
i try but not the same thank you any way
89530-52152 ok learning.rar
hello i find the correct file and is learned
thank you but have problem inside gearbox , is try to learn and stuck the gear ..
thank you
Stelaras26 (8th June, 2022)
