Hi,dump opens in tango 16bit. What do you need?
EEPROM 93C56 - UPA did not read incircuit- read off board.
Pictures attatched.
I haven't used AVDI in a while and all it has now in TAGKEYTOOL, is TOYOTA ALL MODEL, LEXUS ALL MODELS.
When i load either dump, x8 or x16 bit organization, tagkeytool detects it as 4d from visteon immobilizer then gives error "incorrect dump"
Anyway anyone can extract 4c info from either dump ?
On another post another user said that for he used RX300 in Tango to write transponder and it worked.
20Mhz Intel? 80386 CPU - VGA Graphics - 2 MB RAM (16 MB Capacity) - 60MB HDD - SCO? XENIX?
Ok, since AVDI won't program a transponder because it can't recogize the dump but 4C is a fixed one is there a possibility to Insert this is300 4c.jpg
into the dump as KEY 0 / Master Key. then i can write dump back to 93c56
