Results 1 to 10 of 10
    Default mitsubishi L200 immo off ?
    hi,
    i need immo off for mitsubishi L200 2016y diesel 2.5 MT , car was fine since try clone key with vvdi '7936' procedure gos wrong cant clone , and now car start and stop , cant find anny key programmer to programme key 'skp900 , zedfull, avdi , vvdi , tango ' cant reconise car or dump !
    ecu denso 4D56 SH7058 and 93A86 immo with 25320 .
    thank you.
    MartiLer's Avatar
    Dec 2016
    you have erased the crypt in the dump. read your keys.
  3. The Following User Says Thank You to MartiLer For This Useful Post:
    electrohicham (16th March, 2018)
    key read with vvdi .
    MartiLer's Avatar
    Dec 2016
    try it...........
  6. The Following User Says Thank You to MartiLer For This Useful Post:
    electrohicham (17th March, 2018)
    not ok still car start and stop . and no fault code with diag.
  8. #6
    MartiLer's Avatar
    Dec 2016
    Password old.
  9. The Following User Says Thank You to MartiLer For This Useful Post:
  10. #7
    not work still same probleme .
    can programme new key to dump immo manually ?
    did some one test new avdi mitsubishi update to programme key L200 2016+ ?
  11. #8
    MartiLer's Avatar
    Dec 2016
    try again
  12. The Following User Says Thank You to MartiLer For This Useful Post:
    electrohicham (19th March, 2018)
  13. #9
    still not the one , same problem .
  14. #10
    i get a working car i read immo and ecu eeprom and key , can some one chek if can find probleme ?
    thank you.
