OK i do managed to remove the ignition lock cylinder
but now comes the programming part, help please
Hello
I have this car (trailblazer from 2003) and some time start some time immo (car with lock start blinking) and no joy
i connected KL 30 of the PAS reader to KL15 in this way MCU get power only when i switch ignition on and from 10 attempt 8 time engine start
i order the pass reader, problem is i do not know the adaptation procedure, and i cannot remove the old one from the car, pictures will come
Any info is appreciated
Thank you
Show whats inside eeprom or mcu. Swap them and youre good to go
Renault ECU tool / IO terminal / A.S.W
clauberty (19th March, 2018)
Yes is MCU but problem is that i think that is the problem, like in EZS
10-15 minutes to solder and test. Here you wasted more. Swap it or rewrite it you have tools. Easy job
yes it is, have the tools, i read ori mcu and write eep to "new" immo but car do not start
diag error is no signal from transponder so i think i win lottery by receiving a bad immo from USA and i'm in Europe
lat say car do not start car lock icon is flashing: i do ignition off remove connector from immo 5s reconnect immo ignition on and car is starting
