Results 1 to 11 of 11
    Toronto
    Default VW Radio Navigation codes
    I need codes for those files, please.
    I am not sure of the size of the file, but I think it is 24c64.
    I used upa to read it.
    Thank you in advance.
    Oct 2013
    Ukraine
    Quote Originally Posted by jollo View Post
    H
    Try......1891 or 1301
  3. The Following User Says Thank You to masterskay62 For This Useful Post:
    golo (17th March, 2018)
    Aug 2016
    First try 1301
  5. The Following 2 Users Say Thank You to golo For This Useful Post:
    jollo (17th March, 2018), masterskay62 (17th March, 2018)
  6. #4
    Toronto
    For which file, those are two different radios.
    Aug 2016
    Sory for thi file 7L6 035 191 C 24C64 USED
    CODE IS 1891
  8. The Following User Says Thank You to golo For This Useful Post:
  9. #6
    Toronto
    I think the first one is 1309, but I am not sure.
    And the used one I don't know.
  10. The Following User Says Thank You to jollo For This Useful Post:
  11. #7
    Toronto
    I will try now
  12. #8
    Oct 2013
    Ukraine
  13. The Following 3 Users Say Thank You to masterskay62 For This Useful Post:
    golo (17th March, 2018), jollo (17th March, 2018), SIRKVA (17th March, 2018)
  14. #9
    Toronto
    Small problem, when I put the radio in the car it works with out punching in the code.
    I need to install the used one, because the original is draining the power.
  15. #10
    Aug 2016
    For this 7L6 035 191 B 24C64 OR
    works those codes :1301, 1305,1303,3107
  16. The Following User Says Thank You to golo For This Useful Post:
  17. #11
    Toronto
    7L6 035 191 B 24C64 OR -----1301
    7L6 035 191 C 24C64 USED ------1891
    Dump # 1 (Or) I can't check and dump # 2 (used) worked perfectly.
    Thank you to all.
