Results 1 to 11 of 11
Thread: CEM VOLVO S60
    Default CEM VOLVO S60
    car volvo s 60 key lost after read and get keys from 28f400 no ignition cem clic relay on just only check lamp on dash death ,Flash read writh tl866 checked 10times bin identical ,resolder flash ,mayby flash corupted
    can any one help?
    regards
    kiszka's Avatar
    Quote Originally Posted by janusz21 View Post
    can any one help?
    regards
    the car should start
    all ok press rep.
    add key 20 BF 4D 43
    Reality of life :
    1:Never argue with an idiot, he will pull you down to his level and overcome you with experience
    2:Envy is the confession of inferiority
    3:Everyone lies
    How much trash you leave behind so much trash someone will have to read or maybe you yourself
    If you like reading garbage, don't slow down, just speed it up
  3. The Following User Says Thank You to kiszka For This Useful Post:
    janusz21 (18th March, 2018)
    thanks testing this solution not working dash death only ikon ecu ,cem clic clic relay ,
    Jun 2013
    Opens fine in Tang.
    What did you use to add the K
    carprog ori
    ok cem live ,I need help with sync ECU(95P08) with CEM(28f400)volvo S60 2004 y .CODECARD SMAL SOFT NOT work corect Thank's all.
    CAN ANYONE CHECK THE TANGO SYNCHRONIZATION http://www.scorpio-lk.com/downloads/Tango/SM.Volvo.pdf
    Mar 2017
    TÜRKİYE
    0261206828 s80 ateşleme kıvılcım mevcut, enjektör tetikleyici yok
  10. #9
    English please and bin cem and ecu
  11. #10
    Mar 2017
    TÜRKİYE
    523.558 [ATTACH] [/ ATTACH] 523.558 [/ ATTACH] [QUOTE = janusz21; 3267945] [ATTACH]İngilizce lütfen ve bin cem ve ecu [/ QUOTE]
  12. #11
    your eprom ecu look bad , tray read again
