Hello,
Need immo off please from this car mini cooper year 2002 ecu siemens S 118012001LO B file from 29f400
thank again at all MK
Hello,
noone for this immo off
thank
mouss (2nd April, 2018)
Try this file and report... Remember to disconnect ews and bridge the 2 starter wires... Pass in pm
Sent from my LG-H850 using Tapatalk
http://cloud.tapatalk.com/s/5ab10060...cooper_off.zip
I really hate passwords on files.. Especially if you give a like and rep.. Before you find out its a dud file..
mouss (20th March, 2018)
hello
thank for all can you explain me about wire to bridge where foto please ecu is siemens thank
thank but i have starter just synchro ecu with ews i cant do it
ok so i remove ews never plug in car and your file is testing? or not
thank again
Yes. Tested in another car... Its for the Siemens vdo uc2000 type ecus... Remove ews don't plug it in... And bridge the starter wires (the 2 thick ones) at the ews plug...the immo offs are vin specific.. Then put my file on 400bb flash , install and start without ews and starter wires bridged... Ice done a few already... The small Siemens vdo boxes with 2 connector plugs...I still don't know what Siemens box you have there... Still waiting for a pic of the ecu... But the vdos are the most popularly used...
ok thank but if we don't plug ews again why bridge the 2 pin ews and my ecu is siemens from car mini cooper year 2002
thank
hello
here is result car no start i remove ews and bridge starter car want start after recherch i haven.t masse ( -) IN ECU so i think my first file not good ecu is siemens S118012001 year 2002 so now need good file with immo off and try
note fuse and relay all is ok my file is not good so i post new file from member dk
thank again for help
HELLO
I had buy another ecu i connect mpps and read flash obd2 now i have file if someone can do for me immo off for start car
thank in advance at all members DK
thread close all is ok now i had buy i/o terminal and car start immediattly i want say very thank at all members who help me
thank again
Now I can see which ecu you are using... I do not have an immo off for those brother. Sorry. Only for the vdo ecus... Is or not possible to try clone the system from a running vehicle... Ie. Copy key transponder. Copy ews info to yours. And copy ecu info to yours? I wonder if anyone on dk has a lockset clone they can send you?
