Have you reset all remotes adaptation to 0 trough vcds if so than reprogram how many remotes you like if not will not work.
VW Touran 2003
I tried 3 different remotes and I was able to adapt everyone of them , BUT ONLY ONE at the time. (never all together)
I was not able to adapt more then one at the time.
tried
1) FVDI
2) VCDS - > freezes after changing new value from 1 to 2 in (46-adaptation)
3) VAG-CAN pro -> index out of range, when trying to enter 2 as new number of remotes
Seemed to me like the car is set to accept max 1 key in the adaptation procedure.
Or something wrong with the car.
I did this procedure with Golf MK5 many times without problems.
Any idea ?
Please hit the rep & thank buttons if this post was helpful!!!!
I get similar problem. Just was imposible to add any remotes. Only reset to 0. But program was not available. When open add channel everywhere was error .
Renault ECU tool / IO terminal / A.S.W
I had the same issue with Audi TT. My remotes are from China, good quality and very cheap.
I have tryed 4 remotes with no sucess. After long time i got very angry, took kd900 and generated remotes with it.
Car acepted all 3 remotes at the moment. My conclusion is that remotes from China are with the same ID's and the car recognize all 3 just like one.
Try my way.
PS. Also, when erase exsisting remotes with VCDS, do not scroll to "0", type "0".
kamolsf (22nd May, 2018)
That problem usually occurs when you have different part numbers. CC module can accept all that part numbers but only same part numbers if you want more than 1 remote in memory.
H2Deetoo (28th May, 2018)
Thank you,Sir
