Results 1 to 7 of 7
    Oct 2014
    Worm Hole
    Default MB Bclass B180 cdi DPF OFF edc16c32
    Please help with DPF OFF file MB B180CDI 2006 edc16c32. My EGT sensor is damaged.
    Ive tried some solutions, ASC. Swiftec but car still in limp mode 3000RPM and error B19/9 still present. Also the car is automatic and due to limitation remains in automatic mode.
    The error on sensor B19/9 exhaust temp sensors voltage high is present with both original and dpf off file.
    If anyone can help with dpf off file for this ecu with OBD2 reading and all dpf related sensors please help.
    Thank you
    Free doesn't exists, Chep doesn't last
    kumbari's Avatar
    Germany
    Default Here .....
    Quote Originally Posted by obd2exe View Post
    Thank you
    Yur file dpf off !
    Oct 2014
    Worm Hole
    Thank you. Its ASC2017 solution. doesnt work. Error with EGT sensor high still present. Car rpms is limited to 3000RPM
    Sep 2015
    World
    Hi, confirm the possibility remove DPF without dpf pressure and temperatur sensor.
    kumbari's Avatar
    Germany
    I have tested many time that solution and work great
    Bosna
    Try.Good luck.
    Oct 2014
    Worm Hole
    @mvekas sorry friend but i wouldnt dare write this into ECU
    edc16c31 dpf solution works ok, on edc16c32 not
